Motorcycle Wiring Symbol Query Discussion ThreadMotorcycle Wiring Symbol Query Electrical Advice
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other features and I can't find the company wiring anywhere on line. Can someone tell me what the following means?
Mode Switch:
![[ElectriciansForums.net] Motorcycle Wiring Symbol Query [ElectriciansForums.net] Motorcycle Wiring Symbol Query](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/77/77748-cbabb61f24c612463c8372f08b5581a9.jpg)
I know they are momentary switches but is this normally open or normally closed?
If this part on the race switch assembly was designed to use 3 switch (1 up, 1 down, 1 mode) does the earth run to all 3 switches. I think that is what the diagram says but don't want to hook it up wrong.
Stock:
![[ElectriciansForums.net] Motorcycle Wiring Symbol Query [ElectriciansForums.net] Motorcycle Wiring Symbol Query](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/77/77749-e0fd5ebed880b31481628dd2fa841398.jpg)
Now button switches :
![[ElectriciansForums.net] Motorcycle Wiring Symbol Query [ElectriciansForums.net] Motorcycle Wiring Symbol Query](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/77/77750-c576e6e8cfe8fa02289be5434f0d7fd6.jpg)
So:
Is there any way to tell when a switch is momentary or latching from the diagram? I think I know from their function but just curious.
The bike also has a pit limiter that was latching switch replacing the indicator switches. On the race controls it is a single latching button switch. I think it has been wired to the left/right turn signals as this is normal practice. Is this normally open or closed? How would I wire that to a single button switch?
![[ElectriciansForums.net] Motorcycle Wiring Symbol Query [ElectriciansForums.net] Motorcycle Wiring Symbol Query](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/77/77753-21b3d3a08215dc9c5668424e6d860d1b.jpg)
Thank you in advance
![[ElectriciansForums.net] Motorcycle Wiring Symbol Query [ElectriciansForums.net] Motorcycle Wiring Symbol Query](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/77/77746-a7e42470851f6dd68e71adec396ddd4c.jpg)
![[ElectriciansForums.net] Motorcycle Wiring Symbol Query [ElectriciansForums.net] Motorcycle Wiring Symbol Query](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/77/77747-b9fdd8496b2267b9400cb802c743e383.jpg)
Motorcycle Wiring Symbol Query for the original thread on Electricians Forums
Mode Switch:
Stock:
So:
- Up momentary normally open switch = black wire and green wire
- Down momentary normally open switch = black wire and green/black wire
- Set/Mode momentary normally open switch = black wire and green/yellow wire
