Marmox plastic washers.
judge
Evening gang. Would there be an issue laying loose ufh cable over the top of plastic marmox washers i am glue n screwing to an upstairs chipboard floor.Or should i try and work the cable around them instead ?( The main reason i ask is the slight height difference itll make.) Obviously ill be self levelling afterwards before tiling.:smilewinkgrin:
I'd be using hardie to avoid going directly to chipboard....
I read it as he was gluing & screwing (Marmox) to the chipboard hence why using Marmox washers. I just assuming you meant that judge, not directly slc to chipboard?
I was gonna glue n screw 6 mm insulation board ontop of the chipboard,tape the joints,lay the cable,then self level before tiling.I was just a little concerned about the slight height issue as the washers dont sit totally flush on the insulationboard when screwed down.(probablly worrying about nothing but wanted to check first):smilewinkgrin:
Ali-I allways overboard with Hardi but was only going with insulation board for the the thermal properties.
I use the metal ones too, no height issues then. Arent the plastic ones meant for hammer fixing into solid walls/floors?
No mate. There are plastic washers that are identical to the metal ones, only difference is you can't screw down as much as metal ones as the screw just pulls through. I use them a lot still though. They do make plastic "spankers" for solid fixing.
Judge, by the time the screw is in nicely it will only be 1-2mm higher maximum
judge,
The D,
judge,
The D,
