The Lowestoft Tiler
Hi Guys,
I thought i would pick your brains, I think i am doing it the best way but i thought i would ask just in case someone has a better idea?
I have got a job of 36 square metres of tiles for an outside porch. the concrete on five square metre is raised in the middle by 125mm. i need to level this off. I thought i would do it this way:-
Cut lines into the concrete with a diamond blade every 20mm across the floor and then chip it down with a Kango checking levels as i go. do you think this will be the best way as i do not want to gun up the floor as its 250mm thick!
I await your wisdom:yes:
