Discuss Large tiles in the UK Tiling Forum area at TilersForums.com.
L
Leatherface
The simple answer is Do Not Use It.
Tub adhesive dries using air - it in effect dries & the moisture evaporates outwards through your grout lines. Any large format tile applied using tub adhesive is likely only to dry around the perimiter of the tile & not the centre. Always used cement based. This dries using a chemical reaction & hence does not need air.
When using a cement based adhesive on Gypsum Plaster, make sure that you are using the manufacturers recommended primer. Some cement based adhesives will "blow" & tiles are likely to fall off. I use Mapei adhesives - they have a primer called Primer G - which I always use in these situations. Never had a problem.
Some people use PVA - I avoid this simply because Mapei advise the use of Primer G.
Hope this is of help
Reply to Large tiles in the UK Tiling Forum area at TilersForums.com
