Discuss Large floor in the Canada Tile Advice area at TilersForums.com.
Dumbo
on this forum is the only time i've heard a written disclaimer isn't legally binding. if it's not negligence then no case to answer. non use of a decoupler is not a factor that someone could be liable for floor failure! it's not even in BS!
Surely BS should be the minimum standard tiling work
if screeders prepare substrate correctly, mix correctly and put in sufficient expansion joints I feel a lot of these problems should be eliminated.
How many expansion joints do you see in domestics .
Reply to Large floor in the Canada Tile Advice area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
