Kudos aqua4ma boards
Dougs Third Go
Has anyone tiled onto these? and if so what addy did you use? Contractor says that they've used these in the past and found that a normal spf addy struggled to set onto them so he's keen to use a rapid set. I phoned kudos and they said that a normal spf is fine. I don't fancy using a rapid set on walls in summer so I was thinking of maybe using a S2 adhesive such as tilemaster ultimate. Any thoughts appreciated folks :thumbsup:
Hi Doug..
Tilemaster will do you a retarded setaflex adhesive which gives you a couple of hours bucket life!
It's minimum order of 25 bags though?im using it at the mo.
Not used those boards Doug but I can't see why a slow set wouldn't adhere to them even if they are impervious to water.
I tiled the walls and floor on a one a couple of years ago using Weber Set.Rapid SPF without any problems.
Dougs Third Go,
On one,
Dougs Third Go,
On one,
