Is 4mm grout gap on wall ok?
jonty
Just doing my first splashback, in my thinking to get the tile layout good i had to use a 4mm grout gap, but now half way through i thought can i even use this gap on a wall? if i can do i have to use a special grout? thanks for any info
Technically speaking I guess you should use "wide joint grout" but it's normally very sandy and designed for floors, truly horrible to use on walls.
Personally, in both my bathroom and kitchen I have 4 & 5mm joints and both with standard (good quality - i.e. Bal microflex) grouts.
With small tiles you will get through a lot of grout mind.
Most peeps stay away from large grout joints on splash backs for ease of cleaning, although as with my kitchen - some tiles suit a large joint. Use decent grout and do it properly and I don't forsee any problems.
To be extra safe - always good to use an Admix such as Bal GT1 - increases adhesion and flex.
Mapei ultracolour foil bags is flexible 3 to 15 mm and creamy as you like thats the one for you m8
jonty,
jonty,
jonty,
jonty,
