Discuss How to cut circle hole in middle of tile??? in the UK Tiling Forum area at TilersForums.com.
Deleted member 1779
Its easier to cut a perfect 30mm circle into the tile with a diamond tile drill
Guaranteed not to break tiles because they grind porcelain rather than drill.
Also the resulting hole sizes are stronger. This is because they are barrel shaped. With an angle grinder you get a cone shape. A cone shape is prone to chipping when the fittings are pushed through.
A solid barrel makes for a stronger hole compared to a cone. Cones are formed when angle grinders take material from the back of the tile.
In expensive porcelain tiles which can cost from £80psm it is better not to break tiles or risk imperfections during installation. A modest investment of £49.99 will ensure you have the 30mm socket PLUS you will have all the other sizes you need. These sizes will come later when you want fixtures and fittings.
At £49.99 the kit is value for money... And at a later stage you will want the smaller size 6mm and 8mm anyway for your fixtures and fittings.
30mm socket included !
Reply to How to cut circle hole in middle of tile??? in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
