how much to charge to remove tiles?
steve9999
how much to charge to remove tiles?, do you charge so much per metre and what if it needs re-plastering after?
!/2 day or day rate, depending on how many tiles there are.
If it needs plastering, quote accordingly. Hopefully you will need to patch and repair only!!!
Where are you mate? Maybe I can help you with the plastering / tile removal. 🙂
It's always tricky to quote for removing tiles. If they have been tiled on plasterboard you're going to make a mess of it and probably will need to replace it. If it's plaster on render on the exterior wall and plaster on laths internally, again, that's a pig to correct and you'll pull of the tiles carefully and then patch up and re-tile. If it's a bit of a mix then again it's a nightmare to quote for.
What I would do is say to the customer you want X a day, should take you X days/hours, you'll quote them X much but be warned it could be a bit more. Then keep them posted with how it's going and they wont feel ripped off if you need to stick on another £50-80 whatever on the bill.
steve9999,
Dan,
steve9999,
Dan,
