Discuss Homelux Waterproof Membrane to use or not to use?? in the UK Tiling Forum area at TilersForums.com.
DHTiling
Hi...use a rapid setting adhesive to put the mat on the wall with.....this will make it a quicker process to start tiling...........I would recommend a single part flexible white adhesive to tile with and a floor grade flexible grout..i think floor grouts give a better finish to stone....but that's just my opinion some have there own favourites........
But i do recommend at least you use the mat or some sort of tanking in a shower cubicle.........good luck.......
Reply to Homelux Waterproof Membrane to use or not to use?? in the UK Tiling Forum area at TilersForums.com
  • Question
  • Sticky
  • Question
