GrahamC
HI - I'm new to this forum and new to floor tiling.
I am refurbishing my old bungalow - it has suspended floors with 100x50mm joists at 400mm centres, supported on brick sleepers running full width of the room (at approx 1000mm spacing along the joists) with 100x100mm wooden sleepers on these which the joists are nailed to. I have put 100mm celotex insulation between the joists, there is still a 300mm air gap under this for air circulation via air bricks for venting.
I am where I am: flooring on top is W/P (green) T&G 22mm chipboard screwed into the joists with Turbogold 60mm screws at 150mm spacing - all joints have been glued with waterproof PVA. The area is 2 rooms, each approx 3x4m which lead into each other (wall taken down). There is no discernible vertical movement between boards, I do not have UFH, just normal radiators for C/H. 20mm gap between edge of c/board and all walls
I want to tile it with travertine natural stone 12mm thick, random pattern - this is my problem, I have had 3 different opinions how best to do it - all conflicting apart from all advising flexible adhesive and grout at all stages and a movement expansion joint between the rooms
1) prime chipboard then tile away with a good 2 part flexible adhesive eg. Ardex, stonefix or equivalent
2) prime as above, DITRA matting (on flexible adhesive) to decouple the tiles, then tile on that with flexible adhesive - but I undestand this is only good for lateral movement but not vertical movement.
3) 6mm Hardibacker board stuck & screwed to C/board, then tile on this again with flexible adhesive, but if there is any movement then surely this hasn't decoupled the floor and the problem of potential cracking remains.
I think you can see my problem and there is quite a cost variation,
thanks in anticipation of your help - Graham
