Discuss Help..Advice please - pics inc. - tiling bathroom walls. in the Canada Tile Advice area at TilersForums.com.
White Room
South Croydon
Probably a tad to far to pop round, All sand/cements can vary in strength depending on the mix.
What tiles are you going to be fixing to the walls and also is it the whole bathroom....
V
vsp89
That's unlucky mate. Thanks for the thought though much appreciated. The tiles are 30x60 ceramic 9mm thick. I worked it out at around 21kg per square meter for the tiles alone so I'm a bit worried about whether or not it's safe. What's the best method of fixing tiles to this kind of wall?
V
vsp89
Oh and yes it's the whole bathroom
White Room
Personally I've done a tad over weight with ceramic, if the backing is sand/cement I would scrape any loose finish plaster and prime the render and tile on that....definitely wouldn't tile on tile though.
V
vsp89
Thanks whitebeam. Any particular primer you would recommend? Tilemaster prime+grip any good ?
White Room
I tend to use sbr, it covers many areas of building work...some use other brands, just personal preference.
widler
1,328
England
Personally I'd either knock it off and dry line or prime it and dry line over the plaster, looks a bit crap , even skimming it only gets it smooth it won't get it straight.
Just board it, it will take a plasterer a day at the most and cost £80 in gear
Reply to Help..Advice please - pics inc. - tiling bathroom walls. in the Canada Tile Advice area at TilersForums.com
