Currently reading:
Have coated WBP ply with PVA - what to do?
Discuss Have coated WBP ply with PVA - what to do? in the UK Tiling Forum area at TilersForums.com.
DadHelpingSon
Hi all. As name implies Dad is helping Son with renovating his flat. I built a new wall in the bathroom from WBP ply. Plumber (yes I know, why listen to him) suggested coating the ply with 3-1 PVA. I then used Mapei D1 adhesive. Some tiles are coming loose - fortunately have not done too many yet. Mapei say I shouldn't have used PVA and to sand it off. The forums all confirm not to use PVA. It would be a massive job to sand it all. Is there a product (eg primer) I can apply over the PVA? BAL SBR is mentioned a lot - will it go on top of PVA? I can use another brand of adhesive as the shop will take back the uniopened tubs of Mapei.
Also, I need to tile-on-tile on the kitchen floor. Existing tiles are sound. What prep & adhesive?
grumpygrouter
Tiles are bog-standard "Flat white gloss" 25x33 from Tile giant. Overboarding is not an option as the wall is hard against the bath (which has no room to manoeuvre) at one point so I can't increase the wall thickness without demolishing it and moving it. I'll just have to re-treat the wall somehow whatever it takes.
Out with the sander it is then! You may want to try to wash as much off first as you can but don't soak the timber then sand it when it is dry.
33x25 tiles are too big for tubbed adhesive anyway, you need to use powdered stuff really.
Reply to Have coated WBP ply with PVA - what to do? in the UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some...
Renovated the bathroom on my 1970 bungalow last year. Took up the old pink floor tiles with sds. Chunks of what i assume is self leveller or maybe screed (?) came up with them. Left with Concrete...
