You've got 400sqm to do - they advise only mixing 2sqm per batch and fixing with a 3mm bed screed.
Sounds interesting - hope the floor is flat!
we have just had the floors tested 85% rh is the reading we gotGettin there Dave......gettin there.
Paul.....how on earth can you judge if the addy looks "not great" from a picture????
I have seen no failures on anhydrite where this and one other gypsum addy have been used. Additionally where in France we recomend it it has decimated the number of tile delam issues we see.
Not saying other systems don't work.....clearly if everything is done perfectly they do. Simple fact is though the more compatibility there is between products the fewer failures you will see.
The gyspum based addy's can generally be used whilst the screed is still relatively wet (85% RH)
