TinyFlat
Hi New to the forum and new to tiles and underfloor heating. Hope you will be able to take some time to share your expertise. Hoping to get listed building consent for a small conservatory - it will be 45 sq ft floor space - very smalll but all space is valuable where I am (London) and I have a 217 sq ft concrete patio which goes to waste most of the year. I was planning to resurface the patio in lime or slate stone (concrete would need to be levelled first as has sunk in places) and use the same flooring inside the conservatory so the look is uniform and seemless, which will appeal to the conservation officer. However, the stone is 20-30mm thick. I am wondering if this is a good idea or if I would be better off trying to find tiles that look like the lime or slate for use inside the conservatory but are ceramic or porcelain and so not as thick as the stone paving pieces outside? What is better for underfloor heating? I have contacted one company who when I told them said they would install 6mm inscreed heating cable plus a thermostat for £225 inclu VAT with labour to install it being £350 pd + VAT (they said one day) I asked if I should opt for a thinner tile and they then said said it wouldn't make a difference and the inscreed option was the cheapest option. Will ring other firms but wanted to hear thoughts here. I guess a thick stone will retain more heat but perhaps take longer to get warm? The space would only be used for at home working 2 days a week and maybe as a dining space so would need to have the potential for every day use but may not be used every day.
