Matthew77
Thanks for the comments & advice.
I've read elsewhere on the forum that its advised to set out and lay the border first so that the feature tiles don't end up bigger than the borders, OS recommend laying the feature tiles first then the border. Am I right in thinking that the OS borders and tiles will match? As in you would only put a right angle Corner on the border tile at the same point as the feature tiles start a repeat pattern again. For example the pattern & the border are stepped in what widths they can be depending on the width of amount of tiles in the symmetrical repeat pattern, that is then centred and then the variable tiles are put in to fill in the edges...if that makes any sense? so there shouldn't be any/many cuts in the pattern or border tiles?
I believe that OS will supply a plan of this anyway right, but is that the way it works
