Discuss Customer has PLY thickness issues! in the UK Tiling Forum area at TilersForums.com.
bobbin
Turning into a problem this, I have a customer who wants there kitchen (open plan) to be tiled. This a new extension and the dinning room has been laid with oak floor so the tiles need to meet up to it!
The kitchen has a chipboard floor screwed into floor joists, so this leaves about a 20mm drop from the edge of the oak floor.
The problem is I think the floor will need to be plyed with 18mm to ensure it doesn't flex in the future, the kitchen is about 9m square. So with the tiles on top (600 square porcelain) this brings the kitchen floor a lot higher than the oak floor, there's the problem :mad2:
What would you guys do?
Do you ever get this when doing a quote and you explain that you will need to ply the existing floor and raise it 18mm before you even lay a tile to ensure the tiles stay where you put them?
There is always a problem of either meeting a carpet, or the door won't open due to the height etc.
Help as always is much appreciated :grouphug:
grumpygrouter
Ask Darren from NETT, he knows about a ply substatute that is a lot thiner than ply (4 mm) i think.
Good luck.
You will be talking about "No More Ply". Said by the rep on here to be a full strength substitute for 18mm ply but as yet we have seen no written evidence that it does so, only what has been written in marketing literature.
It may be better to use 12mm ply and use the likes of Fastflex or Ardex-flex 7001. Schluter also do a very good "movable" transition which will help reduce the "step" to a slope.
bobbin
Cheers guys, it's a pain most of the time! Have you tiled straight onto chipboard before, after screwing in and priming, I have done it my own shower room as a test about two years ago and not a single problem. I wonder if all this 18mm ply is just a bit over kill sometimes. I mean if you screw enough turbo gold screws into the chipboard, the only way it will move is if the house falls down!
tkm18
Im of the same opinion, but BS's are 18m so some folk like to stick with that.
grumpygrouter
This BS is for situations for strengthening a floor, not just "if it is chipboard it needs to be over boarded" per se.
The main issue with chipboard is the fact that it can be very unstable with moisture. Ply is also unstable with moisture but less so.
If a floor meets BS for deflection then there is no real need to overboard with 18mm ply as it does nothing but add cost and give a step to deal with. If on the other hand the there is issues with the chipboard getting wet, then you have another issue entirely. There are adhesives that have been developed to cater for tiling straight onto chipboard and other timber based substrates (i am not talking floating floors here) and can rightly be used if conditions are right. Some guys on here will not do it and some will. it is down to the guy on the ground at the time to make a judgement call as to which way to go.
These are my own opinions and NOT necessarily that of this forum, I may add.
tkm18
I was talking generaly, not just about chipboard.
With experience you can generally judge what is needed when tiling a wooden floor, sometime nothing, sometimes just tightening up, sometimes overboarding.
silver
Hi, I would suggest the hardibacker board too...top stuff and starts at 6mm.....as with the chipboard and tiling onto it...adhesives will stick to it but I find its the top fibres that break down and away from the rest of the board with moisture....not the adhesive failing If its an area that aint too big.....you can tank chipboard, it will adhere....that way no moisture will reach the board and create the "breakdown" of the fibres. Its supposed to be a no no to tile onto chipboard, however, a recent chip shop floor took me ages to get the *kin tiles off it !
Reply to Customer has PLY thickness issues! in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
  • Sticky
  • Question
