Discuss Creating a fall in floor tiling in the Canada Tile Advice area at TilersForums.com.
jimmi-c
228
Ive been asked to tile a large floor with a drainage gully at one end. The screed is realitivly flat. Am i right in thinking that the screed should form the fall and i just tile to that? Rather than trying to build up with adhesive.
Also another floor upstairs is plywood with a gully in the middle and this has to be tiled so water runs into the gully . How can this be done?
Any help much appreciated
peteablard
1,058
Cheshire
Is this in a commercial environment? I can't remember of the top of my head the correct fall ratio but to drain the water quick enough you could be looking at a drop of up to 100mm over a 5 metre run
jimmi-c
228
They are toilets/changing rooms.
To achieve That sort of gradient i assume the screed would have to be sloping down towards the gully?
What about the ply wood floor? Some sort of pre-formed tray perhaps?
Time's Ran Out
If you have to ask how - you shouldn't be doing it!
This type of work isn't DIY and you will not pick up the experience from a forum.
Contract it out and watch!
Reply to Creating a fall in floor tiling in the Canada Tile Advice area at TilersForums.com
  • Sticky
