Discuss Carpet runner on Marble staircase in the Canada Tile Advice area at TilersForums.com.
mski
Hello, we need to attach carpet tackless onto a marble staircase and the re-finisher recommended aluminum drives. He said not to use the hammer
setting on the drill. Does anyone have experience with this type of installation ? Aluminum drives are specialty fasteners, 1/8'' x 7/8'' long, drill through
the tackless, into the marble, then hammer the aluminum nail into the hole for a squeeze fit. What do you think ? will the marble crack or should this be safe. The tackless gets installed onto the treads and risers (appx. 3/4'' away from the crotch) However, we could probably push that measurement out to maybe 1.25'' away, making the drill hole about 2'' away from the crotch. What do you think ?
Mski
I would go with the suggestion/experience of the re-finisher, I haven't had the pleasure of coming across this situation but it sounds like the finisher has, I would go with what he suggests..
mski
Thanks Angrypirate, he also said not to drill on veins, due to possible cracking and there are veins everywhere. We did a test pc. today using a specialty glue gun with 180 second glue sticks, called ' The Pam Glue Gun ' and even though this system has mixed reviews, it's holding to the marble really well.
Reply to Carpet runner on Marble staircase in the Canada Tile Advice area at TilersForums.com
Teejay
