Discuss calibrated slate on sand/cement screed - prime surface ? in the UK Tiling Forum area at TilersForums.com.
simonjay
I've got some very well calibrated brazilian slate 400 x 600 x 10mm. The back is lightly grooved from the machining.
I also have some Dunlop natural stone and large format adhesive.
The substrate is sand/cement screed well dried (many months old) which is slightly dirty with a few paint splashes on etc. Not very dusty, but SOME light dusting if scraped, etc (like any screed).
Trowel I will use is large format trowel (20mm x 13mm rounded notch at 28mm spacing)
The question is:
Do I need to prime the surface before tiling ?
If so, with what ?
Thanks,
Simon.
simonjay
Yes, the back buttering is the usual thing. Interestingly, the dunlop natural stone and large format adhesive says it is a "new thing" and specifically designed to not require back buttering since it is designed to collapse in a way that guarantees fill coverage. They only recommend back buttering for tiles profiled or studded on the back.
Still, a thin back buttering could do it no harm !
Simon.
Reply to calibrated slate on sand/cement screed - prime surface ? in the UK Tiling Forum area at TilersForums.com
