best diamond blade for granite
sstilingservice
Hi all I have some granite to lay and was wondering which diamond blade people recommend. I have a small plusplugs wetcutter but found when I did some travertine last week my angle grinder was better so think i might use this method again but not sure a normal diamond blade will be up for the job.
thanks for any advise Steve
can you use these dry or would I need to have a hose ready never cut granite befor
An angle grinder and a hose???? :whatchutalkingabout Be careful...no in fact ..Dont do it !!
so dry cut it is then. wasn't sure if it would trash the cutter unfortunatly I dont have room in my car for a nice big full on water cutting system maybe some thing for the future if I start getting a few of these to do.
And if you're doing granite then dont forget your drill bits for the holes.
If you drill outside stick a bucket on a hosepipe to hold it in situ.
Then drill your hole....
And Bobs your uncle!
I can get my Rubi DW250N in my BMW 325tds Touring, no problems ( apart from it being F*****' heavy!), and yes I get my other stuff in too!
Get a Rubi blade if you are wet cutting (breeze through granite) or if you are dry cutting throw a norton blade on the angle grinder (can get from screwfix, brilliant blade).
Both cut much better than the Marcrist, no effort needed atall.
sstilingservice,
penno,
sstilingservice,
penno,
