best cleaner for a slate floor in bad condition???
N
Neil TileTastic
was wondering if any1 has any info on the best cleaner for a slate floor that is in a bit of a bad way and then whats the best sealer to bring it up with a gd shine again many thanx in advance neil
You will need a rotary scrubber to really get them clean and some stuff called Prochem ultrapac renovate.You would scrub the floor with the machine then use a wet vac to clean up the water from the scrub. There a plenty of slate sealers on the market it depends what finish you want, matt or gloss. Dont polish them.
Also lithofin do a good range of cleaners........this one would be good for your project as well...
lithofin MN Power-Clean - 1L
An alkaline cleaner that dissolves and removes oil and grease marks, waxes, gloss films and residues from other floor care products and general soiling. Also for the removal of light cement films during and after grouting. For use on all marbles, polished and unpolished natural and artificial stone.
To restore a slate floor in poor condition, you'll want a cleaner that’s tough on grime but gentle on the natural stone. Here are a few options and steps to help bring your slate floor back to life:
1. pH-Neutral Stone Cleaner
  • Look for a pH-neutral stone cleaner specifically formulated for slate or other natural stones, as acidic cleaners can damage slate. These cleaners are designed to dissolve dirt and oils without harming the surface.
  • Apply the cleaner using a soft mop or microfiber cloth to prevent scratching. If the grime is particularly thick, allow the cleaner to sit for a few minutes before scrubbing gently.
2. Homemade Soap and Water Solution
  • For a more budget-friendly option, mix a few drops of mild dish soap with warm water. Use a soft brush or mop to gently clean the slate.
  • Rinse thoroughly with clean water afterward to remove any soap residue, which can dull the surface.
3. Heavy-Duty Stone Cleaner (for Severe Grime)
  • If the slate is heavily soiled, a heavy-duty stone cleaner made for natural stone surfaces can help dissolve stubborn dirt. These cleaners are stronger but still safe for slate when used according to directions.
  • Apply with a scrub brush if needed and rinse well with clean water.
Additional Tips​
  • Use a Sealer: After cleaning, consider applying a stone sealer specifically for slate to protect it from future stains and restore some of its natural sheen.
  • Avoid Acids: Never use vinegar, lemon juice, or bleach on slate, as these can etch the stone’s surface.
Additional Tips​
Thanks for the content spammer.
I've removed your dodgy link though. Have a good day. 🙂
Neil TileTastic,
Dan,
Neil TileTastic,
Dan,
