Currently reading:
Aquapanel floor
Discuss Aquapanel floor in the Canada Tile Advice area at TilersForums.com.
C
CraigH
Hi,
My bathroom is starting to take shape so I tottered off to my local tile place yesterday, dragging the wife along to choose floor tiles.
Whilst I was there I picked up some 6mm aqua panel for the floor.
So my concerns is as follows, I lay a thin bed of adhesive down. then screw aqua panel down over the top. then tile....
So what happens to all this next time the floor needs tiling? say in 10 years time. won't there be adhesive stuck all over my chipboard floor that will be impossible to get up?
Or am I being thick
Dumbo
Hi,
Or am I being thick
Don't make things to come apart make them to stay together
Dumbo
Thanks everyone, I will do what outcasts on the tin. if there is a tin...
I can't leave it for the next person as it's likely we won't be moving again now. I'm 37 so I doubt this bathroom will see me until I die...
Although a fairly good chance I will be paying someone next time around
When you've done your bathroom the upscale in your property will be so much you won't be able to afford not to move
Reply to Aquapanel floor in the Canada Tile Advice area at TilersForums.com
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
