Another quartz thread
Bopster
I would print off the web-page which says they are fine with ufh and keep it filed!
Ignore any and all advice from Topps and contact BAL technical concerning PTB. I have used it with these and it's been fine, but check with BAL - not Topps.
My advice would be not to use BAL grout as it is a pain for efflorescence. I would pick Tilemaster grout any day, but that's my experience.
They're very easy to cut with a wet saw, but the resin stinks so better done outside.
From last year when I installed these tiles from Topps.
Don’t buy the adhesive and milk from Topps. It’s extortionate.
Ok so cleaning them up is a pain, am I understanding correctly in that after the grout is floated in and wipe as much away as possible I give initial cleaning with a damp sponge once it set a bit then leave to dry then use the residue remover?
Needless to say the plonker in Topps said have plenty of sponges to clean up with
I've never had any issues grouting these, either the proper Gulfstone, or the cheap copies. Just wouldn't suggest contrasting grouts in case of staining is all.
I think residue removers are just usually another Topps' targeted add-on.
(otherwise known as "mug-sales")
Whilst I’m sure ptb may be suitable, personally I’d use Isomats Mega Rapid.
Couple of reasons, one it’s a bottle and bag system with zero water content, and secondly, in this country it would be regarded as a standard set, whereas ptb certainly isn’t.
Mega rapid has a 3 hour pot life at 23 degrees, and I’ve tested that very fact and found it to be true.
Ptb could be used for a thicker bed, but as long as you don’t intend on going thicker than a 10mm solid bed, the mega rapid will be fine.
It is very high yield also, so whilst it’s not cheap, the yield more than makes up for it.
Just my opinion tho.
I agree with 3fall- not that I’ve used Mega rapid but that PTB isn’t great to work with.
I had to use it as it was supplied by my customer but didn’t enjoy it one bit.
Bopster,
J Sid,
Bopster,
J Sid,
