I
igro49
Hi Everyone
It would be great if you guys could comment on how I am going to build my wetroom.
It is on the first floor of a new extension, no floorboards, just 2x8 joists now; two stud partition walls, one wall of aerated concrete blocks (new build) and one solid brick wall that used to be the external wall of the house.
My list of jobs:
1. Noggins.
2. Tuff2 former tray 1400x900. (Chosen after detailed advice on this forum; many thanks for your explanation, Wetdec.)
3. 22mm marine plywood for the rest of the floor.
4. Plasterboard for walls, nailed to stud partitions, adhesive to concrete/brick walls.
5. Dura-CI membrane on the floor using flex adhesive.
6. Dura-WP membrane on the walls using flex adhesive.
7. UFH on the floor, loose-wire because of the funny shape of the room.
8. Flex screed on the top of UFH.
9. Porcelain tiles on the floor, ceramic tiles on the walls, using flex adhesive.
Now, my questions:
First, of course, what did I miss in my list? Is it correct? Are there any better options?
Which membrane is it better to use over the tray itself, Dura-CI or Dura-WP? If it is Dura-WP, is it enough to use 18mm plywood for the rest of the floor?
What else can I do from the point of belt-and-braces approach, mostly regarding waterproofing? I am making the wetroom for myself, and I am happy to go with some extras even if it is overkill, provided the extras make sense. For example, I have read somewhere about a layer of liquid tanking on the top of the membrane – does it make any sense? If I use tile backerboards on the plywood and/or walls in addition to the membrane, probably it will make no harm. (Apart from some pounds from my wallet of course!) Or is it just crazy?
Finally, I would appreciate any advice on minor details of the job (like sanding the tray surface for better adhesion, of which I read on this forum). I am going to do most of the job myself, with casual involvement of a plumber friend.
Thanks all in advance for your patience.
Igro
My list of jobs:
1. Noggins.
Now, my questions:
Igro
