Rf80
Hi all, great forum - I have searched ate rough a lot of threads and found most of the advice I need, just a few things I am not sure of.
I am preparing to lay 600x600x10 calibrated slate tiles in our kitchen, dining room and utility. It's 50m2 in total. The existing floor is a concrete screened block and beam in the kitchen/dining room and a solid concrete base with 100mm insulation under 50mm screed in the utility. I plan to fit 6mm insulation boards, electric under floor mat, covered by SLC.
My questions are:
1. The kitchen already has a very solid porcelain tiled floor, can I board straight over this with the insulation boards or do I have to chisel it all up ( I have worked out that I can deal with the level difference with a double layer of the insulation boards in the dining room)?
2. The slate supplier has supplied a fast set 1 part adhesive ( flexi) for the tiles, can I use this for sticking down the boards?
3. I have got an acrylic levelling compound to cover the heating wire. The floor is already fairly level. I am assuming I can't walk about on the screed with spiked shoes in order to trowel out the SLC level so I have bought a spiked roller to help spread out the SLC as I go. I was planning on getting some mixing helpers in to keep the SLC coming as I poor it due to the size of the area, also i know from a small wetroom i did recently that covering the heating mat 'eats' the slc so am getting plenty of bags in ready! Obviously with a 600x600 tile i need to get it flat. Does this all sound ok?
4. I was planning on a 5mm tile spacer for the slate, would this be usual for this type of tile?
5. And finally what sized notched trowel should I use for the adhesive on the boards and tiles, 10 mm?
Sorry for the long list, but the materials for this job are expensive and I want to get it right!
Thanks for any advice you can give me, I have previously tiled a few floors and walls but this is my biggest job so far!
My questions are:
