doug boardley
what substrate will you be tiling onto rudimm? ply, concrete, backer board?
Discuss Advice on cutting 600x600 polished porcelian in the UK Tiling Forum area at TilersForums.com.
ive got an angle grinder with a diamond blade, think i will have to hire a decent dry cutter.thing is it will have to be able to cut 600x600 tiles wouldnt it.
alan thats a good idea i will see if i can them left off, makes it easier for me.
what sort of primer would you recomend alan?
thanks for the advice
Mapei Tile Adhesive Primer 1kg
http://www.NoLinksToThis/sfd/i/brandimages/MAPEI_r.gif http://www.NoLinksToThis/sfd/i/spacer.gif
1kg. Water-based synthetic resin primer. For use with cement-based tile adhesives in priming plaster surfaces and consolidating dusty floors.
would that be any good?
Reply to Advice on cutting 600x600 polished porcelian in the UK Tiling Forum area at TilersForums.com
