Discuss Adjudication and BS5385 for bad tiling work in the UK Tiling Forum area at TilersForums.com.
jasonh15
Hi
I had a large extension done by a builder under JCT Minor Works (not home owner) which was designed and speced by an architect under a seperate contract.
A large limestone tiled area (nearly 70m2) was laid over wet underfloor heating set in screed and the tiles have subsequently cracked within 6 months with long linear cracks that span across the room.
No expansion joints were put in, no seperation layer was used, the UFH was not comissioned between the screed drying and tiles being laid and the screed was only allowed to dry for about 4 weeks. Doing my research since I have found these faults contravene the BS5383 standards for tiling.
I have tried to settle this with the builder but he will only take 40% fault and believes the architect is just as much to blame as him so I am being forced to adjudicate against the builder. I do not have a right to adjudicate against the architect.
Does anyone know if I can use the BS standard in the adjudication as evidence of his errors. Does the builder have to work to that standard or is it just a guide he can ignore. I am keen not to start a costly adjudication that I can't win.
mikethetile
:welcome:
Hi Jason
we are not encouraged to give legal advice on this forum as its a tiling forum not a legal forum
but from experiance I would suggest you take legal action against your builder
it is the builders responsability to ensure the work is done to a "proper and workman like manner"
bs are the minimum standard that a job has to be carried out to, falling below bs the job is substandard
bs cannot be dismissed by a builder
contact your solicitor as you have a strong case against your builder, pm Dave and he will find a pro tiler near you that will visit and make a report
this may sound drastic when all you want is your issue resolved, but from my experiance once a builder starts apportioning blame to others theres no way back and you will need to find someone else to rectify the works
mike
jasonh15
I had a report done by Webers. The tiles came from Stonell and they arranged for Webers to do it.
It said that lack of expansion joints was the main reason and it needed redoing with weber mesh tech over the screed.
The screed is reinforced but beyond that I've no idea.
The room does have a lot of glazing so can get large heat variation in the room which might be a factor also.
Ajudication is the cheapest route for me to get recourse from the builder and also its the specifiied dispute resolution clause in the JCT contract that was used.
jasonh15
Thanks Jay.
Answers:
1. Possibly not sure - it looks like it has fibres in it
No the UFH was not commissioned before tiling (it was tested before the screed was poured just to check for leaks etc)
2. Around 70mm
3. Once we moved in it was not touched for maybe one month as it was summer. After that the UFH was turned on gradually over approximately 6 weeks to its max temperature
4. Just a perimeter expansion joint. The whole area is about 10m long and between 5.5 and 7.5 m wide.
Reply to Adjudication and BS5385 for bad tiling work in the UK Tiling Forum area at TilersForums.com
