Discuss Tiling round a quadrant shower in the Tanking and Wetrooms area at TilersForums.com.
Q
Qwerty
As long as the 40mm waste pipe attached to the trap is all connected then the waste can be put together after no problems.
As long as you can find the rubber washer & internals! :oops:
Points
83
B64 5QX
Extremely poor working by the work man. I think you should needed to do with expert then all your issues could solved. We recommend you to do work with great and expert persons rather then inexpert person.
Points
293
Leicestershire
I used silicone matched to my medium grey floor tile grout on my quad shower / floor joint rather than white to match the tray. Makes slight variances in the gap lot less obvious.
F
Flintstone
12mm is not an acceptable gap to try and cover with silicone! I think from the photos we all know it’s not been tanked, and it’s almost certainly had underfloor heating fitted onto ply wood and then tiled. Tanking isn’t mandatory so really you can’t pull them up on that.
Reply to Tiling round a quadrant shower in the Tanking and Wetrooms area at TilersForums.com
