Hi, I have been tiling 3 years after selling them for 11, I have slowly been getting faster, more organised and trying new things as I progress, bigger rooms, bigger tiles, new patterns, new types of tiles, stuff I would normally shy away from but im getting more confidence to try new tings out, but the other day a job that was meant to be 500x500mm tiles turned into 800x800mm porcelain tiles and Im crapping myself to say the least!!
Im looking for advice and tips on laying them please, prep, trowel size, adhesive suggestions, cutting and handling tips etc Im absolutetly fine with most size tiles but these things are immense, I need to make sure they are flat and secured once the adhesive is dry. From what I know the floor is concrete underneath the old tiles (customers are removing those) and I assume there will be adhesive residue left.
My initial thoughts are, prime the floor (BAL APD) then use BAL rapid-flex fiber, use a 10x20mm trowel, 3mm spacers. Should I consider using Levelling clips, never used them before as im normally ok at getting smaller tiles flat and flush but a mate suggested trying them? I dont own a large enough cutter and dont really want to buy a decent one yet as the expense is more then I can afford in these uncertain times with covid, but 95% of the cuts are under skirting boards so I can use my grinder, but there are about 4-5 tiles that need a perfect clean straing cut as they are in front of a fire place, I can buy a cheapo one ive seen for £40 but I assume it will be ***** an probably break but as long as the score if ok on the 4-5 tiles I need to cut clean, I can snap the tile over some wood, and it will prob cost as much to hire one for the week.
Sorry to ramble on hahah Any advice would be taken in gratefully, thanks guys 🙂
