365 drill set
Drill life is 2-6 holes on the pack (for retail) but we have built some redundancy into the cores so know they are good for about ten.
What we didnt want was for shop keepers to recieve customer returns and complaints about drill life so we dumbed it right down.
In contrast some other systems make no claims so the customer is in the dark about lifespan.
My fault. Let me reclarify drill wander (drill slip). Yes the drill will slip on any tile without the use of the drill plate/guide.
You must still use the guide plate with our kit to prevent slipping on tiles either fitted to a vertical wall or fitted to a floor.
Once you get started into the tile you can remove the guide and the crown sits into a little groove.
Hope that makes sense. Oh and the above method is my favourite for off wall tiles to pop it over a drain hole and drill with a water source.
R
on another note,
i have used quite a few different drill bits for ceramics lately inc rubi's ceramic set at £55-oo, triangle bits, adjustable bits etc and i have to say i would rather buy a set of 365 drill bits for ceramics alone. much neater and accurate and those rubi sets get jammed onto the centre bit arrrghh....the 365 drill bits last quite alone time and the finished hole is excellent. in a trade where the finish of your workmanship is crucial, then these bits essential
cheers
ed
Thanks Ed (tiler burden) you raise a good point about ceramics.
I cant over stress the results these kits have on soft ceramics. For professional quality finishes produced in seconds these kits excell.
They just blast away all day!
To leave perfect results in any part of the tile.
Even if you never touch a porcelain tile job these kits are a must for every tiler
Like you said above...... "in a trade where the finish of your workmanship is crucial, then these bits essential"
We are about to invest in a set of 365drills. I hope there as good as the pint I'm going tohave tonight.:8:
Hooorraahhhhhhayyyy
We'll join you for a pint then!
(Richy - Nicky - Vicky) 365Drills
how do these fare with tiles not fixed on walls? Ie with no centre piece wont they send the tile spinning or break your wrist?
Nope.
I normally drill my holes on top of a piece of ply, and haven't had that problem once. I've had the drill slip once, on a Travertine tile, but that was my own fault for not having enough weight on the guide. The only time i've had a tile break was also down to me... Badly laid out Ceramic tile, left the hole too close to the edge of tile; kept shearing the corner off.
As for keeping the drill wet, i always have a bucket of water next to me, and alternate between drilling and dipping in the bucket. It's a little bit slow, but leaves your hands free.. Thinking about making a new guide out of 18/22mm ply, that way i can just fill the hole with water and just drill away! 😀
Great stuff.
We are recovering from our night out too and have decided to count our booze intake on a daily basis as part of [DLMURL="http://www.drinkaware.co.uk/tips-and-tools/drink-diary/"]drink-aware.
[/DLMURL]
Now drinking black coffee
:coffee:
got my drill kit this morning thanks richard, quick delivery and a good price for what i hear is a good bit of kit ,thanks again,steve
365 drill set
james,
james,
