1st time using Natural Stone Tumbled Travertine tiles - help needed please.
tonyn45
Hi,
I have brought some of the above tiles from Wicks and would like to know the best way to fit them to a kitchen wall (being fitted just above the worktop upwards to 30cm high.
What is the best adhesive to use and where can I buy it (wicks, homebase, B&Q??)
What is the best sealer to buy and again where from?
Do I fix tiles first then seal and grout afterwards?
What is the best tool to cut the tiles?
Any help would be greatly appreciated.
Tony:mad2:
Adhesive would be a single part flexible white, an acylic primer on the walls first....
I would fix the tiles first, then grout but you may seal once then grout so it's easier to clean, then seal again when they are dry.
You will need a wet cutter
Hello Tony and welcome...
What wall substrate do you have, they will need to be flat..
Hi Tony,
The best way to install natural stone tiles is ,1st apply a coat of latex sealer on the walls to remove dust from the wals 1 part latex 4 parts water.The best glue to buy is Mapei apply a screan of glue with a comb trowel then stick tiles and apply spacers in between.After 8 hrs apply grouting and lean several times with a damp sponge.
Bye
Mario
visit a tile shop such as Tile giant and they will advise on primers sealers and adhesives,
tonyn45,
The Legend; Phil Hobson RIP,
tonyn45,
