1st Square Hole
jaydebruyne
Thought I'd share my 1st square hole I did in this ceramic tile.. I'm rather pleased it didn't crack on me.
Used a 16mm 365 diamond bit in each if the corners and then a carbide bladed jigsaw to cut out the waste tile.
Lastly filed down the excess.
It ain't perfect but the accessory would cover it up anyway 🙂
Tomorrow's task? Using my new angle grinder and diamond blade 🙂
Let's see what damage I can do with that!! Haha
Looks like the blade has strayed a bit. How did you brace the tile to stop it chattering against the jigsaw?
The file strayed :/ live and learn!! Will aim for a neater cut tomorrow..
I used rubber tipped clamps to hold the tile on my workbench to secure the tile in place. I need to get a rubber mat to sit the tile on really so it takes the vibrations but I didn't have one so laid it naked on the wooden slat..
you could of also nibbled it out with some pinchers mate but grinder is also a good quick way 😉
another tip also is to try and get these to fall on a grout joint you cant always but most the time it doesn't compromise the set out
Noted! Thanks.. 🙂
I was just practising though in case the situation arose that I'd need to do it.
1st Square Hole
jaydebruyne,
mz30,
jaydebruyne,
mz30,
