E7DC016F-DB2B-4465-B0C1-D55CDE39338F.jpeg CB5F44AF-FD57-4D61-A0CE-6AA57A51FA05.jpeg
Excuse me if I'm being thick but isn't the scale a waste of time? Surely if you're levelling a floor, not just raising the whole level of a perfectly flat floor, they'll be reading different depths? Has to be better just to use marker pins set level then fill to the top of those.
stick them to floor
set 360 laser on floor
measure down from laser line to high stop of floor
say 50 mm reading
you want 5mm of SLC as a min depth
at each stick measure down 45mm from laser line and cut.
if floor is not level this will leave sticks at different lengths
SLC to tops of each stick to turn a unlevel floor to a flat floor
stick them to floor
say 50 mm reading
So as I said, the scale is a complete waste of time!
Nice idea, until they come unstuck when you start pouring and they end up floating about in the slc. :tearsofjoy:
GoneGuy,
demi34,
GoneGuy,
demi34,
