Italy
thanks for the cazzo.....Thank you Antonio, you are a true Cazzo.
Discuss It’s New tools tuesdays in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
yes, I confirm marc, mine when it was new was fine, a few chips, but now many more
But in Italy it costs € 59 and my work still after 3 or 4 years.
So the solution I tried to have no chips is this.
example of a 30mm hole.
mark the 30mm circle with a pencil, drill with 25mm bits,
use the tapered countersink up to the mark of the pencil.
clean the hole with 20mm of £ 100 without getting to the glaze.
I know it's a long job but it's the only solution I've found.
I guarantee that the conics do not make chips.
So pay a bit more attention to grit numbers when looking at tools like this. It's quite important.
Personally I do, but you’d still expect an item from montolit costing just shy of £100 to work.
The diamond coating is very fine and evenly spread too.
Very disappointing I must say.
impossible, they come from Florence. See the FI plate? It is the country of matteo renzi the CAZZARO TOSCANO
Yes tried variable too.What are running it in? A grinder?
What about a vacuum brased hole cutter that’s a finer grit than the usual chippy type, do they exist ?
Yeah they do, I have a worn out one. Trouble is don’t know who makes it and tool store I bought it from has gone now. It’s very kool cos you can replace the barrel as opposed to the whole thing.What about a vacuum brased hole cutter that’s a finer grit than the usual chippy type, do they exist ?
Has anyone tried the Montolit Killer Gres?
They look like a Diamond sintered hole saw which is segmented.
Most of the VB holesaws I have seen and used tend to be fairly rough. Funnily enough the finger bits I just tested are very fine compared to the same brand of hole saw and cut much cleaner.
iHas anyone tried the Montolit Killer Gres?
Reply to It’s New tools tuesdays in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
