Discuss Is there a visual difference between the different types of screed in the Tile Adhesive / Grout Advice area at TilersForums.com.
RWoods
36
Hamphire
My new laid screed floor has been down for 4 months and from reading up I probably need to seal it prior to tiling.
Unfortunately I cannot get hold of the builder to find out whether it was a cement screed or flow/anhydrite type screed. Is there a visual way to tell (ie color/finish) that would let me know what was used?.
Or is there some kind of universal sealer that would work with either type.
I have been recommended Kerakoll Biogel for the adhesive if that makes a difference and the tiles are wood effect 120x20 porcelain.
H
hmtiling
Post some pictures of the screed.
Have you checked how level it is? If it's perfectly level chances are it's anhydrite
Cranbrook
598
Pontypridd, South Wales
RWoods
36
Hamphire
pics attached. It looks pretty level throughtout.
RWoods
36
Hamphire
So without having to trawl the forums i've 100sqm to seal. Whats recommended for sealing and how long do I have to leave it after?. I plan to use an Idrobuild Tex anti crack mat inbetween tiles and screed and from what Ive seen PVA is a nono.
Cheers for the help its much appreciated
Reply to Is there a visual difference between the different types of screed in the Tile Adhesive / Grout Advice area at TilersForums.com
