Bill
So are you not putting insulation boards on top of the floor first?25mm is the worst part, parts are much lower. its going over retro fit wet underfloor heating mats, hence the use of leveller.
Discuss Using SLC to bring existing floor height to the height of extension floor. in the Canada Tile Advice area at TilersForums.com.
Do you not think he may mean polypipe or similar?What’s the underfloor heating system that your proposing to level over ?
I thought retro fit mats meant after the solid floor was in?Do you not think he may mean polypipe or similar?
As it’s a retro fit wet ufh system?
The way I interrupt the situation is that the original house is 25mm lower because there’s ufh in the new screed and a retro fit system will be fitted to the existing and then levelled over to bring it up to one level.I thought retro fit mats meant after the solid floor was in?
Reply to Using SLC to bring existing floor height to the height of extension floor. in the Canada Tile Advice area at TilersForums.com
