Discuss Bosch floor laser GSL2 in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Bosch GSL 2 in operation, single line means perfectly level, if the lines open up, your floor has a rise or fall in it.
Instant visual check on how good your floor is, and clients don't even need to know anything about construction, just be able to know the difference between 1 or 2 lines.
A target indicates the direction of deviation from level.
Two speed sweep of the area, seriously couldn't be easier.
Simple but very useful.
Once rest of mat is down, that's gonna be one flat and level floor!
So how did you end up cutting the tiles around the units?
Haven't got there yet Paul, only started laying today, but what do you mean exactly mate?
This is that failed anhydride, so we're reinstating a new floor. Changing from
900 x 900's to 1800 x 900's
Ahhhhhh right doh! Haha
I'm sure you're right Andy.
Didn't need to, once the floor started coming up, there was no stopping it. One or two tough bits, but nothing that requires a hammer and bolster, just a good swift prod with a floor scraper.
There were even a few stuck down with what looked like Bal's S2 superflex or whatever it's called these days. That black sticky crap. :D
What's with the lattice effect? Combed one direction on floor and opposite direction on the tile ?
Yes looked like it Andy, Delia Smith would have killed for a pattern like that on her Apple Pies! :p
Couldn't understand it, the bed varied from minimal to 11mm it was madness.
The floor was as flat and level as a snooker table! :)
Yeah a little sanding and a splash of primer! What would that have saved in ££££?
Thing is Lee, it was sanded!
The client even quizzed then as to what the sander was for! :eek:
Just not well enough.
Most of the laitence had gone once floor was lifted.
Gave it a quick going over back to aggregate, primed 50/50 with Isomat flex primer (ready mixed) then two neat coats before it stabilised.
Isomat AK22 and Tilemaster mat.
Reply to Bosch floor laser GSL2 in the Tile Tools | any Country any make any model area at TilersForums.com
mcgtech
