Discuss Tiling on Tiles in a kitchen in the Canada Tile Advice area at TilersForums.com.
Tom the tiler
Hi guys,
My first time on here and found some interesting information too. I don't do a lot these days, but the wife is requiring changes within the kitchen.
I would like some advice on a project I have, which is to tile my kitchen floor on top of existing tiles. The tiles that are in place are sound,flat and level I have been recommended to seal the existing tiles and to use a flexible adhesive and grout. I would like some advice on the best sealer to use along with the best adhesive and grout. I am led to believe that Mapei is the best but I am willing to take advice from this forum. I also, would like advice on the smallest spacer size to use along with these so-called levelling spacers that are around. The tiles I am laying are similar to laminate flooring boards but narrower so there is a chance the level would be affected.
Thanks guys. (guys is a unisex word and therefore refers to males as well as females) No offence intended.
Tom
Dan
Admin
5,039
1,318
Staffordshire, UK
What's the floor like under those tiles? How long have they been down?
I'd avoid lash clips / levelling clips if it's flat.
And 3mm minimum for floor spacer size. It's the british standard. Though depending on the tile type you could do a bit smaller if the sizes on them are spot on. You'd cause yourself issues if the tiles are not bang on.
L
LM
Sean Kelly
1,068
Ruislip
Tom, Welcome.
Lee has suggest some good products there. I used Prim Grip on a ceramic kitchen floor last year. Roll it on with a roller. I gave it a couple of coats, but bear in mind that the drying time could take longer than stated on the tub.
If you are laying wood effect planks then stagger them like this:
Go for a 3mm joint as any difference in tile size will show up less.
Good luck.
Dan
Admin
5,039
1,318
Staffordshire, UK
Thanks for your reply Dan I appreciate it. The house itself is just 10 years old and the floor is sound, the tiles are all sound too. And you recommend levelling clips yes?
If you're tiling a level floor I totally don't no. I don't think I would on anything personally but some use them.
Tom the tiler
If all the tiles are solid and sound then degrease the floor first Tom with something like what's in the link below and then use the below primer and your good to go.
No Nonsense Heavy Duty Degreaser 5Ltr - http://www.NoLinksToThis/p/no-nonsense-heavy-duty-degreaser-5ltr/88668
products - http://www.mapei.com/GB-EN/Products-for-Wooden-Floors/Binders-for-screeds,-smoothing-compounds-and-additives/ECO-PRIM-GRIP
LEE MAC, Thank you for your valuable information I shall purchase these products. Could you offer advice on a suitable Tile Adhesive, I have been recommended Mapei Flexible adhesive, but there is a fair amount of choice & I would like to make the right choice now.
Tom the tiler
Tom, Welcome.
Good luck.
Thanks for the advice Sean my tiles are exactly the same as the photo you uploaded. However, I am a bit OCD and had planned to stagger the tiles but on a 50-50 basis, but if you give me a reason why I shouldn't lay them this way then I am prepared to take on board your advice.
Reply to Tiling on Tiles in a kitchen in the Canada Tile Advice area at TilersForums.com
