Setting Out Bathroom setting out
Discuss Bathroom setting out in the DIY Tiling Forum area at TilersForums.com.
P
Paul Lewis
Surely there can't be that much variation in size or it would be impossible to to get straight grout lines?
Also I don't have to measure every tile do I?
WetSaw
There can be a considerable difference in tile size. +/- 2mm is not unusual so if you have one that's 2mm bigger and one 2mm smaller, well you get the idea!
Open random boxes and check a few, you should do it anyway especially if you're trying to preplan to the mm.
P
Paul Lewis
I'll have a look when im home later. It's turning into a bit of a mare haha.
So what are the general rules for setting out?
WetSaw
General rules about setting out? Don't let an engineer do it!!
You normally aim for whatever is aesthetically pleasing, be it centering a window or wall to allow even cuts. There's usually going to be a compromise somewhere though so generally you try to put that where it's less visible, behind the door for example.
P
Paul Lewis
Oh dear I'm an engineer haha. Is it that obvious.
I was trying to centre round the window as best I can without leaving small cuts but I think I'm going to have to compromise somewhat.
WetSaw
P
Paul Lewis
It's had a tanking membrane painted onto it. It will be tilled in the same tiles as the rest of the room
Reply to Bathroom setting out in the DIY Tiling Forum area at TilersForums.com
