Discuss 3 way corner joint tile trims needed in the UK Tiling Forum area at TilersForums.com.
R
RobInHerts
Hi all.
Does anyone know where I can find 3 way 'corners' for tile trims?
I am using 9mm chrome tile trim (Homelux) along the top of my tiles as I am only tiling to 2/3 the height of my room.
I have now come to a 'boxed in' water pipe section, so need to use the trim vertically on a 90 degree external corner which will then meet the trim at the top of tiles.
A three way corner joint. Homelux only appear to make corner joints for corners from 2 directions!
Many thanks,
RobInHerts.
R
RobInHerts
The problem I have is the two corner joint I have doesnt quite fit in the right way.
The trim im using is curved, but in a certain way, so that the two corner joint would be ok for a 90 degree corner on a flat so when you look at the trim it is a square, but not 3 dimensionally (does that make sense???)
But I need one that will go round the corners of the boxing, so that my vertical trim can then but up beneath it. Some have suggested doing some clever mitring / cutting of the verticle trim and then the two horizontal trims can meet it at each side.
Is this feasible or just too difficult?????
regards,
RobInHerts
frogeye
Hi
see here http://www.tilersforums.com/threads/cutting-tile-trim-3-way-mitre-with-pictures.3605/
as Turkish said - it is a pain in the butt, but it can be done - see the excellent post above
My only advice is, if you have to do it, ( and I am an advocate of the natural look ) allow plenty of scope for making good on the angle - in other words , don't expect to use a piece of trim cut to length and make the mitre cuts 1st time - it took me 3 goes - then I trimmed the other end to fit, job done, but never again (literally!!)
frogeye the friendly gardener
macten
1,158
Nottingham
I think it's worth perfecting the 3 way mitre.
I took a few hours out one day and kept practicing until I'd got it nailed.
Only had to use it once so far though
Reply to 3 way corner joint tile trims needed in the UK Tiling Forum area at TilersForums.com
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
