Discuss Bevelled Metro Tiles..... Trims, edges and window reveals. in the DIY Tiling Forum area at TilersForums.com.
Chris Bates
Hello,
This is the first time of posting and hope that someone can give me some advice or posing me in the right direction.
I've tiled successfully in the past and, in my opinion, done a decent job, but now face fitting bevelled tiles.
My question relates to the height of the tile trim around window reveals and edges.
My first idea was as drawing A. This allowed a thin quadrant edging and finished with a good edge next to the trim. Great so far.
Looking around I have only seen it done as B. Where the trim is at the same height as the top of the tile. This, in my opinion, looks messy as there is lots of grout around the bevel and we see a cut tile at the edge.
Then we move onto the window reveal, the quadrant trim has to be as drawing B, because of the cut tiles.
Can anyone recommend the neatest way of fitting the trim on Bevelled Metro tiles.
Andy Allen
1,318
Gloucester
What about leaving the biscuit back exposed ?
Painters chalk....
Trouble you get with metros is the middle of the tile is 8mm the top 6mm so an 8mm trims on the top ends up with a horrible lip......personal choice really.....I've done it both ways but hate the lip at the top.
Yeah there's always the difference in thickness between the bevel and cut. I don't think it looks bad. Personally unless it's a rustic tile I think no trim doesn't look right on an edge.
Chris Bates
Thanks for your comments.
Spinning the tile around as Drawing A appears not to be recommended.
I did consider not using trim on the edges, but I reckon on the tile edges look unsightly, these days.
I think I'll get some trim, cut a few tiles and mock something up.
Chris
Reply to Bevelled Metro Tiles..... Trims, edges and window reveals. in the DIY Tiling Forum area at TilersForums.com
Bevelled Metro Tiles..... Trims, edges and window reveals. > Tiling Advice - Tilers Forums
Chris Bates
Hello,
Andy Allen
1,318
Gloucester
Painters chalk....
Chris Bates
Chris
