Discuss Linear drain reccomndations..? in the Tanking and Wetrooms area at TilersForums.com.
1,223
On a rock in the middle of the sea.
I'm looking for an 800mm against the wall linear drain for home.
I usually use Marmox or Wedi trays which have them built in or a Schluter when i'm screeding the falls but the Schluter one has the outlet to the side and i'm needing one with the outlet in the middle and to the front.
It's going to be screeded in for use with 20x20 mosaic.
Any reccomenadtions?
Kerdi Line F will do it. It's illustrated with the drain facing up the tray, but just as easily installed opposite way round. Very low level too.
That looks just the job Impish mate. ;)
If you've used Schluter drains before like me - you'll know they're just a doddle to install and totally safe!
Even when you have to get "creative" with the falls etc...
1,223
Its the Kerdi Line H that ive used in the past but that F with the front facing outlet is new to me - its not got as much of a flow rate though but should still do th job :thumbsup:
Reply to Linear drain reccomndations..? in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
