How Many M2 Are You Getting With Slc
I seem to only manage little over 2m per bag over Ufh wires, and I'm only just covering the wire! What do you usually expect to get?
I can only go by what I know of the Palace Self-Level. that is 1.7kg per mm per sqm. Wires about 5mm thick....... ish? that should only give a coverage of 2.3 sqm, so sounds about right.
Which leveller you using and what thickness of wire are you covering?
Tiling on Underfloor Heating
Flintstone,
Old Mod,
Flintstone,
Old Mod,
