Discuss Wet cutting machine in the Canada Tile Advice area at TilersForums.com.
The runi 250 nl is pretty good and cheap enough for something you wont be using everyday
- - - Updated - - -
Ment to say Rubi!
cliff jones
For 30mm thick marble, forget bridge saws and go with the Flex CSW4161 plus guide rail.
Man handling 30mm thick slab on and off a flat bed and lining it up mm accurate is a ball ache! 20mm is sensible - but 30mm you're into the world of stonemasonry as opposed to tiling, so it's time to take on some of their equipment.
Never considered that, but always a fan of Flex tools, so will defiantly have to consider it if it makes my life that little bit easier :smilewinkgrin:
Reply to Wet cutting machine in the Canada Tile Advice area at TilersForums.com
