Shower enclosure problems
Can you take an overall picture of your shower enclosure and one showing the installed shower
First of all I really appreciate your input but I dont understand your request?
I could take a picture of the installed shower, as it is insalled??
i think he means can you take a picture of the enclosure as a whole and the installed shower as well??
Yep.
From everything that has been said and described over this post i'm not convinced it's coming through the tile round the back and out onto the floor. If your insisting the Silicon on the outside of the enclosure is dry when this happens then it may be a plumbing issue from say the shower.
Ali. Im sure it is where I say and not a plumbing issue. It leaks when water is directed onto the corner I say.
I think its the shower enclosure or channel as if the water was getting under the bottom tow of tiles it would probably seep straight down onto the floor boards and then onto the joists and ceiling but not out the side.
tapatalk on my HTC
I agree with you Mike but sedated says no water comes through where the enclosure is fixed to the wall and the Silicon is dry.
i think it's getting under the shower enclosure (where the red arrow is pointing to in post 40 pic 1 ) and is finding it's way to where the water is coming out
I still think the shower is failing behind the channel
The fellas who fitted the shower came back and let the shower run for about 5 mins.
Whilst the shower was running they kept saying that the channel behind the enclosure had Silicon on, yes it had as I had done it. (As previously stated the gap between the shower tray and tiles was super small less than a millimeter in some places, to me that’s not a big enough expansion gap). They then fit the uprights placing a blob of Silicon on the bottom of them before fixing to the wall. so they reckon that they had fitted as per usuall.
They argued this over and over, at one point more or less saying that I must have been pointing the shower head at that area to prove a point and not really showering! And that I made it leak on pourpouse. I only directly aimed the shower head on that corner once to see where it was leaking from. Anyway if it was sealed propper why would water come out there?
I do think that with the tray slightly flexing with use, a small expansion gap and maybe them disturbing Silicon by refitting shower)
…., anyway guess what happened , water appeared outside the shower.
They refuse to take it down and ask that I get a couple of plumbers in to take a look and they will foot the bill. If I get plumbers in they wont see anything anyway and it will be a case of having the shower ripped out, and I think that will jeopardise the seals on the glass and the rest of the joints on the shower enclosure. It is a prebuilt enclosure and the first time they took it out it required force I don’t think it would take much more of the same.
They also suggested getting the manufacturers involved as water could be getting through the glass seals and making its way out via shower frame!. But again even if water was getting into the shower frame then water should not breach the Silicon seal in the upright channel that they swear time and time again is adiquate.
Dunno what to do, fed up!
The fitter did suggest I Silicon this bit (blue) but surely the water will get in further down (Where red arrow is pointing) , and still find its way into the wall? Following the path of the red arrows. Is this bad advise?
howdo,
i know someone said not to Silicon around there,but aint you meant to sit this part of the frame on a blob of Silicon as you fix it to the wall,so siliconing there shouldent matter ?
personally id say its leaking throuth that point,the wall tile when cut around the tray has not been siliconed and there is a gap and the water is sucking under the frame leg going through the gap and wetting behind the tiles. me,id seal it where the blue is and see if that works,easy enough to take off after:thumbsup::thumbsup:
Sedated,
AliGage,
Sedated,
AliGage,
