Tiling on caber flooring on a new build
brickyman
Hi all. I am tiling a few floors for a friend on a new build. Is it ok to tile straight over caber flooring? Its well fixed down and i was thinking a thick coat of PVA and flexible adhesive and grout should do the trick. Any thoughts?
thanks
Hi, never heard of the term caberfloor but it looks like chipboard to me. Personally i would over board with 15mm wbp or tile backer boards. Big no no to pva also, always use acrylic primer for tiling!! Some have tiled on chipboard with no problems but it's not worth the risk.
DEF No to pva...it has no place in tiling. Much better to use a proper acrylic primer and definately overboard with a cement based backer board....as long as you have no deflection!
9mm ply is too thin and will warp if it gets wet. Use 6mm hardie backer, much more suitable for the job.
brickyman,
brickyman,
brickyman,
brickyman,
