Discuss gyvlon screed in the UK Tiling Forum area at TilersForums.com.
You've got 400sqm to do - they advise only mixing 2sqm per batch and fixing with a 3mm bed screed.
Sounds interesting - hope the floor is flat!
we have just had the floors tested 85% rh is the reading we gotGettin there Dave......gettin there.
Paul.....how on earth can you judge if the addy looks "not great" from a picture????
I have seen no failures on anhydrite where this and one other gypsum addy have been used. Additionally where in France we recomend it it has decimated the number of tile delam issues we see.
Not saying other systems don't work.....clearly if everything is done perfectly they do. Simple fact is though the more compatibility there is between products the fewer failures you will see.
The gyspum based addy's can generally be used whilst the screed is still relatively wet (85% RH)
monday ajax will give another coat of primer first
Bit cheeky I know but any chance I could come up and take some pics? Would be interested in putting a case study together for the website.
i dont see why not the job is in grimsby, bradley . for clark construction
im the subby for b.w shrimpton ltd
Oh I know all about that one. Spoke to Baz the other day about it. I put him in touch with Creative. I guess you can probably blame me in that case. Will pop in sometime either Monday or Tuesday and try not to make a nuicance of myself.
broken link removed
interesting read what ever amount of adh you mix you cant re temper (re mix to make workable)
I guess that is becaue it is gypsum so once it starts to set and you re mix it (bit like plaster) it will then go off like stink. I assume that is why they said 2m2 at a time - It would probably take the average DIY tiler 20 or 30 minutes to lay this with smallish tiles.
I know Sab their new tech manager is awaiting new and more descriptive brochures for the gear.
sounds like it might be a pain to use may have to clean after every mix (adh bucket) as to not shorten life of next mix :mad2:
Reply to gyvlon screed in the UK Tiling Forum area at TilersForums.com
