Currently reading:
Primer required?
Discuss Primer required? in the UK Tiling Forum area at TilersForums.com.
Scholester
Hi,
I have done a few tiling jobs for myself over the past few years and would rate myself as reasonably competent!:lol:
I like to ask questions before going in head-first so as to limit any avoidable mistakes.
So, first question for you hepful chaps is..... I am laying UFH in my flat (kitchen & bathroom) which is constructed with block and beam floor with 100mm polystyrene insulation and 22mm chipboard floor. I am using 6mm insulation panels which I believe need to be stuck to the chipboard floor with Rapid Set Flexible Adhesive.
Now, do I have to first prime the chipboard floor with acrylic primer before sticking the boards down and do I have to prime the top of the insulation board before applying the Adhesive for the tiles?
Finally, The UFH mat is 3mm thick, can I lay the mat within the wet Adhesive and lay the tiles directly on this or do I have to lay the mat on a thin bed of adhesive first and let this go off before the tile adhesive bed and tile!?
Hope I am making myself legible!?
TrumpersUnited
The Chipboard will have to be very secure. I would use thicker contruction board than 6mm as well at the very least 10mm. Make sure contruction board is screwed as well as stuck down using a SPF. Also i would use a suitable levelling compound for the UTH and then use a 2 part adhesive and flexible grout.
As the other fellow says if its a floating floor be very careful:thumbsup:
doug boardley
if your chipboard is just sat on your insulation and there is no joists secured to your block and beam floor, and therefore no fixings in your chipboard to the joists to anchor everything to the b&b floor, then it's a floating floor, so you're going to get a lot of bounce and movement within the floor.This will lead to tiles cracking and de-bonding whatever adhesive you use imo:thumbsup:
Reply to Primer required? in the UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some...
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
