Currently reading:
charging for materials
Discuss charging for materials in the UK Tiling Forum area at TilersForums.com.
grumpygrouter
If you supply meterials for a job and the customer pays for all of it, I would think that they would expect to retain title to the goods they have paid for. If you only use a tub and a half, charge a tub and a half and take the rest home. If you charge for 2 tubs, and keep half yourself, an awkward customer could be upset. In reality, unless you are stipulating in detail what you are supplying, the customer won't know, so it wouldn't really matter but the POTENTIAL is there to cause problems.
I never itemise materials, just a job lot figure.
Hope that helps.
Grumpy
IvegotsTILE
Bollo*ks to leaving the spare mats with the customer,goes on my next job so I don't have to shell out for the stuff again.Charge the next customer for it.
If you say use tub and a quarter you still have to pay for 2 tubs so you don't want to be charging for one and a quarter.The last 3 splashbacks I've done needed just more than one tub each so over 3 splashbacks the customers paid for 6 tubs but I only used 4,thats an extra £25 in my pocket.My customers are always happy.
They wouldn't use what we leave behind anyway and it would go to waste,if they did use it then I'm missing out on a job for them.
Reply to charging for materials in the UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
